PicoZed SDR Software-Defined Radio picozed ip address
  • Subscribers 358 subscribers
  • Views 989 views
picozed ip address
How do I find the IP address being used by the eth0 port on Picozed?  I have eth0 connected to a network switch, and I have Picozed connected to HDMI display.  I can boot picozed, and get the "Applications Menu" displayed.  Then I start Terminal, do ifconfig, but the response for eth0 does not contain inet.
Note, my ultimate problem is getting Picozed interfaced to Matlab on Linux host. On a Linux host, I have to go through the Mathworks Manual Install, which so far I've not been able to get working.
Thanks -- Jeff
  • mbrown
    0 mbrown over 10 years ago
    Does your switch support DHCP?
    PZSDR will request an IP address from your router/switch. Otherwise, you'll need to assign it an IP address on you network using ifconfig eth0
    /Matt
    0 e14 Contributor over 10 years ago in reply to mbrown
    Thanks for reply.  Not sure about DHCP. However, I like the idea of setting a static IP for the PicoZed, since that seems to be what Matlab wants anyway.
    How do I set the static IP on PicoZed?  Do I need sudo? What is the sudo password?
    Thanks again -- Jeff
    Figured it out.  From within PicoZed Applications Menu, use sudo to change PicoZed IP address.  No password required.
    sudo ifconfig eth0 xxx.xxx.x.x netmask xxx.xxx.xxx.x
