PicoZed SDR Software-Defined Radio Possible errors in User's Guide?
  • Subscribers 357 subscribers
  • Views 403 views
In the "PicoZed SDR Z7035-AD9361 User's Guide v1.0.pdf" page 38 it refers to the JX3 connector. Many of the pins are labeled with "JX2". For example, pin 25 is labeled IO_L02_12_JX2_P. Shouldn't it be IO_L02_12_JX3_P?
  • mbrown
    0 mbrown over 10 years ago
    Yes, thank you Arlen.   Those were typos and are corrected in ver1.1 of the doc, which will be published this week.
    In Table 20, the signal names such as IO_L06_12_JX2_P, should be IO_L06_12_JX3_P.  This is true for all diff pairs 1-16.
    The master .xdc file is correct.
    Matt
