PicoZed SDR Software-Defined Radio Need SuperSequencer firmware for new silicon
  • Subscribers 358 subscribers
  • Views 732 views
The latest version v1.4 of the ADM1166 SuperSequencer firmware did not work for me. When I recalled that firmware text file, I got the following error message:
The file you are recalling was created using an old revision of silicon.
Therefore the reserved state is incorrect for this device.
Since I have a new silicon version, I cannot use this released firmware text file. Can you please create and release the same firmware v1.4 text file using the newer version of the silicon so that I can use this firmware in my PicoZed SDR SOM?
Thanks!
  • mbrown
    0 mbrown over 9 years ago
    Hi John,
    We've seen this a few times. You can safely click through that warning and continue with programming using the latest configuration file (.txt) on GitHub -- https://github.com/analogdevicesinc/PicoZed-SDR.
    /Matt
    0 e14 Contributor over 9 years ago in reply to mbrown
    Matt,
    OK, I see that the configuration file is working correctly.
    Thanks for your help!
