RFSoC Boards Warning- TX PLL not locked, Please double check hardware setup
  • +1 person also asked this people also asked this
  • Replies 8 replies
  • Subscribers 361 subscribers
  • Views 3164 views
johnj0806
johnj0806 over 4 years ago
I am using the Avnet RFSOC Explorer for MATLAB to interface with ZCU208+DTRX2.  I am following the setup instruction.  Whenever I click the TX Power UP, I get the error "Warning- TX PLL not locked, Please double check  hardware setup".  I am not sure what I am doing wrong as I have verified that I am outputting 122.88 MHz ref from CLK104 module.   Any ideas?
  • mbrown
    mbrown over 4 years ago +2
    Absence of a reference clock for the DTRX2 LO PLLs would indeed cause this error, but you've already verified that 122.88 is present. A few other things you can check... Confirm that the two RED…
  • mbrown
    mbrown over 4 years ago in reply to mbrown +2 verified
    We also see the DTRX2 PLL fail to lock when the external 12V power supply is current limited. Can you verify that your external supply is capable of delivering >2A? In practice, if you can deliver…
  • johnj0806
    johnj0806 over 2 years ago in reply to mbrown +2 verified
    The board was replaced and the problem was fixed. Thank you.
  • mbrown
    0 mbrown over 4 years ago
    1. Confirm that the two RED power-good LEDs on the DTRX2 are on?
    2. Did you prepare the SD Card as described in the Getting Started Tutorial?
    3. Can you confirm that the SD root has a folder called "pll-configs"?
    Let me know what you find. We should be able to get this debugged quickly.
    /Matt
  • johnj0806
    0 johnj0806 over 4 years ago in reply to mbrown
    Matt,
    Thank you for your reply.
    • The two Red LEDs (D4 and D6 are ON.
    • I followed the tutorial on the getting started tutorial.
    • PII- config exists.
    • I also try to use a CW from a sig gen to generate 122.88MHz ref.
    Am still not getting any lock.
    Any help is appreciated.
    -John
  • mbrown
    0 mbrown over 4 years ago in reply to johnj0806
    Hi John -- thanks for verifying those items. Sorry it's still not working. Which version of RFSoC Explorer are you using?
    I would suggest upgrading to v2.2. We squashed quite a few bugs in that release, though the Getting Started Tutorial should work just fine in previous releases, so I'm not sure what's going on with your setup.
    DTRX2 cards are tested at our contract manufacture, so unless something happened in transit or in your lab, the hardware should be good.
    Next debug step...
    WIth the board powered on, open RFSoC Explorer, establish a TCP/IP connection, and enter the following API command:
    >> [status, data] = Avnet_RFSoC_Explorer('Read_DTRX2_EEPROM');
    Please post back the contents of status, data,
    /Matt
  • mbrown
    +1 mbrown over 4 years ago in reply to mbrown
    In practice, if you can deliver 1A to the board you can power up the TX chain OR the RX chain, but not both.
  • mbrown
    0 mbrown over 4 years ago in reply to mbrown
    Hi John - did this solve your problem?
  • johnj0806
    +1 johnj0806 over 2 years ago in reply to mbrown
  • mbrown
    0 mbrown over 2 years ago in reply to johnj0806
    Thanks for letting us know!
  • lightcollector
    0 lightcollector over 2 years ago in reply to johnj0806
    Hi, can you say which board was the issue?  The Otava board, the ZCU208 or the add-on external clk104 board that plugs into the ZCU208?
    Thank you
