RFSoC Boards Matlab R2025 Compatibility Issue with RFSoC ZCU208 from AMD/Xilinx
  • Subscribers 362 subscribers
  • Views 275 views
Saeedk74
Saeedk74 11 months ago
I am having issues communicating with RFSoC ZCU208 from AMD/Xilinx using Matlab R2025a, but I have no issues with R2024b! The issue seems to be related to the  AVNET RFSoC Explorer toolbox not supported in R2025a. Appreciate it any ressonse on this.
  • lightcollector
    lightcollector 11 months ago
    Hi, HDL Coder for RFSoC ZCU208 does work with R2025a.  Even if RFSoC Explorer says it doesn't support R2025a, I believe it will still install (adds it to the Matlab path) the plugin folder that enables the ZCU208 to work with HDL Coder.
    You did not communicate any specific details of your issue, so I can only try to guess.  The install instructions are a bit convoluted since we try to cover older Matlab versions as well.  Please make sure you have all of the other support packages installed, and for R2025a you must install the ZCU216 board setup just as it states in the instructions.  Avnet HDL Coder Support Documentation — hdlcoder-docs v1.0.0 documentation
    Kind regards
  • mbrown
    mbrown 11 months ago
    RFSoC Explorer v3.3.0 supports R2024b and R2025a and has been tested on both versions.As lightcollector requested, please send more details - screen shots, error messages, host PC OS version, etc. so that we can help diagnose the problem.
    Thanks /Matt
