Software Application Development AXI VDMA works, but the bottom few lines are not proper
  • Replies 13 replies
  • Subscribers 363 subscribers
  • Views 1847 views
Hi, all
I am trying to make a simple vdma test demo on zedboard.
Here is my steps.I want to send my own picture(32-bit per pixel) for FPGA  processing.
  1. I read my own picture to memory and copy them to DDR.
  2. Using video dma core to send the input stream from DDR to my own pcore;
  3. Samely, recieve the input stream from my pcore to DDR;
  4. Finally, Write the output stream from DDR.
But i found the results in the bottom few lines are not proper, always comes with paceket loss?
Any ideas to fix this bug?
    Did you flush the cache?
    Did you mean flush the vdma cache or OCM cache?
    From what I understood you use the MM2S Channel of the vdma, to the send an image from the ARM to the FPGA.
    So the CPUs L1/L2 cache.
    Thanks for tips. Did you mean i must use fflush function in my programming begging? Now I increased the Vertical Size, such as 1000 to 1024, the results is OK.
    No, fflush() does something completely unrelated.
    Are you on bare metal? Then try a Xil_DCacheDisable() in the beginning of your program.
    Oh, I am on Linux, not on bare metal. I found the Xil_DCacheDisable() in Zynq BSP, this function cannot use under linux. Any similar function to do this on Linux?
    How do you access the Memory? From Kernel or Userspace?
    And if userspace, do you mmap or something else?
    Two methods I have done: insmod linux driver module or use mmap to operator registers.
    Details please, for mmap you could for example set pgprot_noncached() in the kernel.
    Oh, I use mmap such as: clear memory for DDR start address
    void clearMemory(unsigned long startAddress, unsigned long size)
    tint fd = open("/dev/mem", O_RDWR);
    tunsigned long int i = 0;
    tunsigned char *virtual_addr_in;
    tvirtual_addr_in = (unsigned char *)mmap(NULL, size, PROT_READ | PROT_WRITE, MAP_SHARED, fd, (off_t)startAddress);
    tfor(i = 0; i < size; i++)
    t{
    ttvirtual_addr_in[i] = 0;
    t}
    tmunmap((void *)virtual_addr_in, size);
    tclose(fd);
    In the beginning of programming, i use this function to clear MM2S and S2MM Start Address.
    And my application is under linux-digilent kernel(https://github.com/Digilent/linux-digilent).
    In his xilinx_dma driver (https://github.com/Digilent/linux-digilent/blob/master/drivers/dma/xilinx_dma.c), it uses dma_pool, so I think this is a coherent dma mapping.
