Software Application Development How to modify the RamDisk image that comes with release 14.5
  • Replies 7 replies
  • Subscribers 363 subscribers
  • Views 1730 views
I want to modify the RamDisk image file inside the archive 14.5-qemu-ramdisk.image.gz and include my own custom program in it. This version of RamDisk came with the latest version of linux released for zed board as downloaded from http://www.wiki.xilinx.com/Zynq+14.5+-+2013.1+Release
I tried following the instructions on http://zedboard.org/content/zedboard-modifying-your-ram-disk-image
But the command mount -o loop ramdisk.image mnt does not work for this particular RamDisk image (version 14.5). I get the error "invalid argument".
    Strip the mkimage header...no problem
    gunzip, ok...
    mount -o loop ramdisk.image fails...
    with "invalid arguement" ...
    Any help?
    What you're doing is mounting the image like it's a filesystem, so you have to create a folder ("mount point") and mount the image on that folder. Here's me doing it, notice how I create the folder, mount the image on it, ls to see what's in it (here is where you would add your program), then unmount and do another ls to show the folder is empty now.
    chris2@lindev:~/rd_test$ ls
    ramdisk.image.gz
    chris2@lindev:~/rd_test$ gunzip ramdisk.image.gz
    ramdisk.image
    chris2@lindev:~/rd_test$ mkdir tmp_mnt
    chris2@lindev:~/rd_test$ sudo mount -o loop ramdisk.image tmp_mnt
    [sudo] password for chris2:
    chris2@lindev:~/rd_test$ cd tmp_mnt/
    chris2@lindev:~/rd_test/tmp_mnt$ ls
    bin  dev  etc  home  lib  linuxrc  lost+found  media  mnt  opt  proc  root  run  sbin  sys  tmp  usr  var
    chris2@lindev:~/rd_test/tmp_mnt$ cd ..
    chris2@lindev:~/rd_test$ sudo umount tmp_mnt
    chris2@lindev:~/rd_test$ ls tmp_mnt/
    chris2@lindev:~/rd_test$ gzip ramdisk.image
    Then do your u-boot wrap and you should be good to go. Hope that helps.
    I'm trying to do the same as farseer but i can't gunzip the uramdisk.image.gz.
    /arm-devel/ramdisk/sdcard# gunzip uramdisk.image.gz
    gzip: uramdisk.image.gz: not in gzip format
    The file I downloaded is different as yours:
    mine: uramdisk.image.gz
    yours: ramdisk.image.gz
    could that be the reason? how could I gunzip that file ramdisk image?
    Thanks!!!
    hi ,
    did you solve it ?
    In case you still need this:
    That uramdisk file is wrapped with a u-boot header that you need to strip off, before feeding it into gunzip:
    # dd if=./uramdisk.image.gz of=./ramdisk.image.gz skip=16 bs=4
    More info here: http://www.wiki.xilinx.com/Build+and+Modify+a+Rootfs
    This doesn't work for me, after going from uramdisk.image.gz to ramdisk.image.gz to ramdisk.image, I cannot mount it:
    $ sudo mount -o loop ramdisk.image zed
    mount: you must specify the filesystem type
    $ file ramdisk.image
    ramdisk.image: ASCII cpio archive (SVR4 with no CRC)
    $ /sbin/fdisk -l ramdisk.image
    last_lba(): I don't know how to handle files with mode 81a4
    Disk ramdisk.image: 0 MB, 0 bytes
    255 heads, 63 sectors/track, 0 cylinders
    Units = cylinders of 16065 * 512 = 8225280 bytes
    Disk ramdisk.image doesn't contain a valid partition table
    Apparently I had to follow the instructions as a CPIO archive... Which they say is _not_ for the zedboard, but nevermind.
