Software Application Development Compiling software for ZedBoard, and using BuildRoot
  • Subscribers 363 subscribers
  • Views 1100 views
Hello all,
I just got a ZedBoard and started playing with the default install.
I have plenty of questions but the two important ones are:
1) How do I cross-compile a basic C program for it ?
2) How can I rebuild the system using BuildRoot ?
Before you say RTFM, I did, but everything is geared towards using the Xilinx Design DVD provided with it. As I'm the software guy, in the past I avoided using this huge thing while working on other Xilinx cards (ML405 derivatives) by:
- having the electronics guys use it for their designs (with the appropriate BSP) and only provide me with the dts file
- get BuildRoot and build a toolchain for the ML405, uClibC and a BusyBox OS with it.
- get the linux-xlnx.git kernel and cross-compile with the buildroot toolchain and the previous dts
- embed the busybox target cpio filesystem in the kernel
- put the kernel on a flash
- write a very basic bootloader to read the kernel from the flash, store it in memory and jump to it.
I tried doing that but don't see any options for ZedBoard and/or Zynq in BuildRoot. Or is it under other names ?
If BuildRoot is not the proper way to go, what _minimal_ part of the large Vivado/ISE DVD do I need to install in order to get the cross compiler.
PS: the documentation, like here (http://www.wiki.xilinx.com/Build+Kernel#Zynq) mentions 'make' without a word about the cross-compiler configuration. Something's missing.
    About the first question, I quickly found that the following does the job:
    $ sudo aptitude install gcc-arm-linux-gnueabi
    $ /usr/bin/arm-linux-gnueabi-gcc Hello.c
  • bhfletcher
    0 bhfletcher over 13 years ago
    Did you see the Linux training we offer here? It sounds like you are very experienced with Linux, but the labs with that training may be helpful.
    http://www.zedboard.org/support/trainings-and-videos
    http://www.zedboard.org/course/implementing-linux-zynq-7000-soc
    Bryan
