Software Application Development SDK Issue
  • Subscribers 363 subscribers
  • Views 653 views
SDK Issue
Just installed 14.6 Xilinx tools on a Windows 7 OS.
I'm going through the "Lab 2 Hello World" lab and get this while building my BSP.
Anyone seen this before? I checked write/administrator privileges. Could it be a license issue?
14:38:25 **** Build of project standalone_bsp_01 ****
make -k all
libgen -hw ../system_hw_platform/system.xml
t
t       -pe ps7_cortexa9_0
t       -log libgen.log
t       system.mss
libgen
Xilinx EDK 14.6 Build EDK_P.68d
Copyright (c) 1995-2012 Xilinx, Inc.  All rights reserved.
Command Line: libgen -hw ../system_hw_platform/system.xml -pe ps7_cortexa9_0
-log libgen.log system.mss
Staging source files.
Running DRCs.
Running generate.
Running post_generate.
Running include - 'make -s include "COMPILER=arm-xilinx-eabi-gcc"
"ARCHIVER=arm-xilinx-eabi-ar" "COMPILER_FLAGS= -O2 -c"
"EXTRA_COMPILER_FLAGS=-g"'.
Running libs - 'make -s libs "COMPILER=arm-xilinx-eabi-gcc"
"Compiling xadc"
arm-xilinx-eabi-ar: creating ../../../lib/libxil.a
arm-xilinx-eabi-ar: unable to rename '../../../lib/libxil.a'; reason: Permission denied
make[1]: *** [libs] Error 1
  • bhfletcher
    0 bhfletcher over 13 years ago
    Are you launching SDK from PlanAhead? Instead of that, will you try exporting only from PlanAhead and then launch SDK separately?
    Bryan
  • bhfletcher
    Also, what is your path to the tools? Did you use the default?
    Bryan
    0 e14 Contributor over 13 years ago in reply to bhfletcher
    I can figure out how to launch the SDK outside of PlanAhead, but I don't know how do I load the project into the SDK. Sorry for being a noob.
    I wish the tutorial would tell you a bit more about what each step was really doing.
    using default paths.
  • bhfletcher
    0 bhfletcher over 13 years ago in reply to e14 Contributor
    It sounds like you may be using ZedBoard. Although not specifically written for ZedBoard, the Tutorial 02 that was written for MicroZed could be followed for ZedBoard as well if you would like to see how to import a hardware platform after launching SDK standalone.
    Bryan
