Software Application Development Perl sound script
  • Subscribers 363 subscribers
  • Views 447 views
Perl sound script
I've just messed up my sound script /usr/local/bin/zedboard_sound_setup.pl in xilinux and now sound don't work anymore (i didn't saved a copy of the original). Can someone send me that script?
    The indentations are lost, but it should run fine.
    #!/usr/bin/perl
    use warnings;
    use strict;
    my $smbus = '/dev/xillybus_smb';
    my $readaddr = 0x71;
    my $writeaddr = 0x70;
    if (fork() == 0) { # Sleep and feed the wait() call
      sleep 2;
      exit 0;
    my $pid = fork();
    if ($pid) {
      # Poor man's timeout:
      if ( wait() != $pid) { # Our sleeper died first
        kill(9, $pid);
        die("Failed to program the sound chip (timeout)
      exit 0;
    write_i2c(0x4000, 0x00); # Core clock off, hence PLL off
    # Settings for 25 MHz -> 49.152 MHz
    write_i2c(0x4002, 0x0c, 0x35, 0x0b, 0x61, 0x1b, 0x01);
    while (1) {
      my @vals = read_i2c(0x4002, 6);
      last if ($vals[5] & 2); # PLL is locked
      print "Waiting for sound chip's PLL to lock...
    # Kick off the PLL
    write_i2c(0x4000, 0x0f);
    write_i2c(0x40f9, 0xff, 0x03); # Enable all clock generators
    write_i2c(0x4015, 0x01); # Device is serial port master, Zynq is slave
    write_i2c(0x400a, 0x0b, 0x08); # Left: LINN (mic) unmuted, 0dB gain, no boost
    write_i2c(0x400c, 0x0b, 0x08); # Left: RINN (mic) unmuted, 0dB gain, no boost
    #write_i2c(0x400a, 0x01, 0x05); # Left: LAUX (line in) unmuted, 0dB gain
    #write_i2c(0x400c, 0x01, 0x05); # Left: RAUX (line in) unmuted, 0dB gain
    write_i2c(0x400e, 0x42, 0x42); # Pre-gain 0dB, unmuted, single-ended
    write_i2c(0x4010,0x09); # Mic bias on, 0.9 x AVDD, high performance
    write_i2c(0x4019,0x43); # ADC control: On, inverted analog input
    write_i2c(0x401c, 0x2d, 0x00); # Mixer 3 on left DAC, 0 dB, no rec loopback
    write_i2c(0x401e, 0x4d, 0x00); # Mixer 4 on right DAC, 0 dB, no rec loopback
    write_i2c(0x4020, 0x05, 0x11); # Mixers 5, 6 for line out, 0 dB
    write_i2c(0x4023, 0xe7, 0xe7); # Headphone left and right enabled, 0 dB gain
    write_i2c(0x4025, 0xe6, 0xe6); # Line out left and right enabled, 0 dB gain
    write_i2c(0x4029, 0x03, 0x03); # Playback enable on both channels
    write_i2c(0x40f5, 0x01); # Enable the DSP
    write_i2c(0x40f6, 0x00); # Don't run the DSP
    write_i2c(0x40f2, 0x01, 0x01); # Routing Matrix: Bypass DSP
    exit 0;
    sub write_i2c {
      my ($addr, @bytes) = @_;
      open(WH, ">$smbus") or
        die("Failed to open $smbus for write
      print WH  pack("C*", $writeaddr, ($addr >> 8) & 0xff ,$addr & 0xff,
    tt @bytes);
      close WH;
      return;
      # This code is never reached. Remove the "return" statement above to
      # activate readback. Note that it's normal to get a warning on address
      # 0x4007, since the PLL lock bit can go high quick enough.
      my @readback = read_i2c($addr, scalar @bytes);
      for (my $i=0; $i<scalar @bytes; $i++) {
        warn(sprintf("Address 0x%04x: Wrote 0x%02x, read back 0x%02x
    tt $addr + $i, $bytes[$i], $readback[$i]))
          if ($bytes[$i] != $readback[$i]);
    sub read_i2c {
      my ($addr, $numbytes) = @_;
      open(RH, "<$smbus") or
        die("Failed to open $smbus for read
      print WH  pack("C*", $writeaddr, ($addr >> 8) & 0xff ,$addr & 0xff);
      close WH; # This induces a stop condition on the bus
        die("Failed to REopen $smbus for write (???)
      # Push any character $numbytes times to roll the state machine for read
      print WH  pack("C*", $readaddr).('X'x$numbytes);
      close WH;
      my $data = "";
      my $rc = read RH, $data, $numbytes;
      close RH;
      die("Read failed: $!
    ") unless (defined $rc);
      die("Received too little data ($rc bytes instead of $numbytes)
        if ($rc != $numbytes);
      die("Weird bug
        unless (length($data) == $rc);
      return unpack("C*", $data);
    Great! Thanks for helping.
