Software Application Development can i read Temperature from ZedBoard ?
  • Subscribers 364 subscribers
  • Views 998 views
100gma
100gma over 12 years ago
hello,
How can i read the current temperature from ZedBoard, i don't need to run an OS like Linux or others ( like thisuser http://www.zedboard.org/content/temparature-sensor#comment-4824 ), just i search a solution to get temperature values, so i will code PL ( FPGA) to launch an alert ( like LED for exemple ), when this value exceed a specific avarage ?
also, i don't need an extrnal peripheral https://www.em.avnet.com/en-us/design/drc/Pages/Maxim-Pmod-Compatible-Plug-In-Peripheral-Modules.aspx
Windows 7 ( 64bits )
Xilinx suite 14.7
vivado and SDK 13.4
ZedBoard
thank you
    You can use ChipScope to read the temperatures of the internal temp diodes on the ZedBoard Zynq.  You do this over the JTAG Interface on ZedBoard.
  • 100gma
    0 100gma over 12 years ago
    hello,
    i receive this solution from xilinx forum
    You can use XADC,Have a look at the below pdf.
    http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
