Software Application Development xil_printf and interrupt problem
  • Subscribers 364 subscribers
  • Views 767 views
Hi Experts,
I design a simple hardware to copy a BRAM buffer from PL unit of my zedboard to internal memory .
when BRAM buffer is filled an interrupt occurs and my Interrupt service routine copies data from BRAM to internal memory.
But when I use xil_printf to show buffer contents onscreen, I find that my interrupt routine does not called anymore  and pends until xil_printf function calls finishes.
Does xil_printf pends interrupt?
Regards
Mehrdad,
  • zedhed
    0 zedhed over 12 years ago
    Hi mehrdad_58,
    Hmmm, that is a rather strange behavior.  How is it that you know for sure that your interrupt routine is no longer being called until xil_printf() completes?
    If you take a look at ps7_cortexa9_0libsrcstandalone_v3_09_asrcxil_printf.c is making repeated calls to XUartPs_IsTransmitFull() which is found in the ps7_cortexa9_0libsrcstandalone_v3_09_asrcxuartps_hw.h file.  That printf() code does not appear to be tampering with interrupts at all.  Are you sure that your ISR is being called asynchronously as an interrupt handler?
    -Kevin
    0 e14 Contributor over 12 years ago in reply to zedhed
    Dear Kevin,
    Thanks for the answer,
    I find what was the problem.
    In interrupt routines which are generated from PL to PS, routine is supposed to clear the pend bit of generated interrupt by writing 1 to dedicated bit position of interrupt pend register.
    I also should mention that I use Xcugic routines to handle interrupt and my interrupt line is connected to F2P pins of zynq processor.
    Anyway thanks for the answer.
