Software Application Development How to program registers of spi
  • Subscribers 363 subscribers
  • Views 888 views
Good Day
I work with zedboard ,I have to program the registers of the SPI as slave ,I read all the Labs and the examples.c but I could not do that ..
Please if there are some documents or links could help me.
Thanks in advance
jassim
  • bhfletcher
    0 bhfletcher over 13 years ago
    Are you referring to the Zynq SPI controller? Or the QSPI Flash? Or some SPI device attached to the SPI Controller? Please provide more detail.
    Bryan
    0 e14 Contributor over 13 years ago in reply to bhfletcher
    Thank Mr Bryan for your reply
    yes I work with ZYNQ spi controller , I built CAN controller(using VHDl) and  SPI as a master in the PL part and I want to connect them to cortex A9 using the SPI found on(PS)part as slave .but I can not understand the examples code.c that supported by XILINX.
  • bhfletcher
    Why not use the CAN controller in the PS?
    Bryan
    I am looking for some source or tutorials for implementation of spi protocol between two zedboard devices.
    Kindly suggest if you could.
    Please take a look at UG585 zedboard peripheral user guide. Ch.17 for programming SPI on zedboard.
    Also there is a source code for programming SPI a sample in the SDK.
