Software Application Development Using HDMI display with Linaro and linux-xlnx Kernel
  • Subscribers 363 subscribers
  • Views 280 views
Hi guys,
I have a system on the Zedboard running Linaro which uses the linux-xlnx kernel from Xilinx
https://github.com/Xilinx/linux-xlnx
I want to use the HDMI display with ADV7511 working with this.
I found the following Analog Devices project:
https://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq
But that uses its own version of kernel linux which has the driver code in:
linux/drivers/gpu/drm/adi_axi_hdmi
Can I port these drivers to the linux-xlnx repository or are there any drivers already existing in linux-xlnx to make the HDMI display work ?
Please help me with this
Brad
  • zedhed
    0 zedhed over 12 years ago
    Hi Brad,
    Have you looked into the Xilinx Base TRD design for ZC702 board?
    http://www.wiki.xilinx.com/Zynq+Base+TRD+2013.3
    This is an example of using the Xilinx kernel with a hardware platform which supports the ADV7511 device.
    Following the path of this design on ZedBoard may be easier for you to achieve your goals.
    -Kevin
