Software Application Development Alternative Compiler and IDE
  • Subscribers 363 subscribers
  • Views 398 views
Hi all,
I wanted to ask you, if any one of you has already tried to program a bare-metal application with another compiler then the xilinx-gcc and/or with another IDE then the Xilinx SDK.
I wanted to know this, because I'm not really happy with the automatic vectorization of the gcc.
I think this compiler is not intelligent enough, to vectorize more complex software-projects.
And I hope, that other compilers are more intelligent.
Thanks in advanced for your replies.
Jan
  • ansab
    0 ansab over 8 years ago
    Dear Jan,
    I am also facing the same problem with the compiler as you. I want to use Clang/LLVM instead of default GCC compiler that vivado SDK uses. If you have figured out any solution and can me then it would be a great favour to me.
    Kind Regards,
    Ansab
