Software Application Development [SOLVED] Custom ramdisk
  • Subscribers 363 subscribers
  • Views 348 views
Dear community,
I am trying to build a custom ramdisk image using buildroot. I use a slightly modified buildroot configuration file based on the one found at http://www.wiki.xilinx.com/Zynq+14.5+-+2013.1+Release
With my custom ramdisk, boot hangs after the line "
Uncompressing Linux... done, booting the kernel.
With the original ramdisk (from https://www.digilentinc.com/Data/Products/ZEDBOARD/ZedBoard_Linux_Design.zip) the system boots.
Has anyone succeeded building a custom ramdisk?
SOLUTION:
My ramdisk is larger than the default 8 MByte. Unfortunately, you have to patch u-boot and the device tree file to enable a larger ramdisk.
  • zedhed
    0 zedhed over 13 years ago
    Hi wachag,
    Building a RAM disk image containing a root file system pieced together from scratch is a topic covered in the "Implementing Linux on the Zynq-7000 SoC" SpeedWay training course on the ZedBoard.org training page.
    Keep in mind the one covered in this training course is made by hand rather than using buildroot.
    -Kevin
