Software Application Development Microzed LED using Linux
  • Subscribers 364 subscribers
  • Views 679 views
Hi guys,
Im using Microzed, ubuntu 16.04 and buildroot.
Im just trying to turn on and off the LED using this command :
  echo 906 > /sys/class/gpio/export           //I tried echo 47 but I had an Invalid GPIO 47
  echo out > /sys/class/gpio/gpio906/direction
  echo 1   > /sys/class/gpio/gpio906/value
but nothing happens!
Any help? Thx
  • zedhed
    0 zedhed over 10 years ago
    Hi fourat,
    Getting the GPIO numbering is a bit tricky since the numbering scheme keeps changing on us as Linux evolves.
    Do you have Debug FS option turned on in your Ubuntu kernel?  If so, you may be able to see which GPIO controllers are available by evaluating /sys/kernel/debug/gpio as seen in this tutorial here:
    http://falsinsoft.blogspot.com/2012/11/access-gpio-from-linux-user-space.html
    This has helped me track down GPIO issues in the past so perhaps it will also work for you.
    -Kevin
    0 e14 Contributor over 10 years ago in reply to zedhed
    Hi zedhed,
    thank you for your prompt reply.
    I tried to do as you said but when I access /sys/kernel/ I dont see debug the only things there are the following:
    fscaps   notes                           uevent_helper
    mm       rcu_expidited             uevent_segnum
    any help?
    I think I have solved.
    You have to export gpio953 to turn the led on and off.
    Good luck
