Software Application Development Linux access BRAM hangs
  • Subscribers 363 subscribers
  • Views 880 views
eric97
eric97 over 9 years ago
We are using a Zedboard with Xilinx Linux and Vivado 2016.3 SDK.  We allocated a BRAM in the PL side and then try to access the BRAM in PS.
The BRAM in PL:
        axi_bram_ctrl_0: axi_bram_ctrl@40000000 {
            compatible = "xlnx,axi-bram-ctrl-4.0";
            reg = <0x40000000 0x2000>;
            xlnx,bram-addr-width = <0xb>;
            xlnx,bram-inst-mode = "EXTERNAL";
            xlnx,ecc = <0x0>;
            xlnx,ecc-onoff-reset-value = <0x0>;
            xlnx,ecc-type = <0x0>;
            xlnx,fault-inject = <0x0>;
            xlnx,memory-depth = <0x800>;
            xlnx,s-axi-ctrl-addr-width = <0x20>;
            xlnx,s-axi-ctrl-data-width = <0x20>;
            xlnx,s-axi-id-width = <0xc>;
            xlnx,s-axi-supports-narrow-burst = <0x0>;
            xlnx,select-xpm = <0x0>;
            xlnx,single-port-bram = <0x1>;
And after the zedboard boot, when I try to access the BRAM address with:
"devmem 0x40000000 w" the Linux system hangs. However, when I tried with "devmem 0xe0001000 w" (the serial port), Linux system returns successfully. Look forward to any suggestions. Thank you.
Eric
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Eric,
    Have you taken a look at this post?
    https://forums.xilinx.com/t5/Welcome-Join/Acces-BRAM-from-PS-and-PL-sections-in-Zynq/td-p/684386
    --Josh
