Software Application Development Zedboard AD data collected by continuous transmission through Ethernet
  • Subscribers 362 subscribers
  • Views 271 views
On zedboard, add custom AD on the AXI bus acquisition of IP core, want to AD collection of data sent to the PC via Ethernet.
Now do the custom IP is registered as a mixed equipment, write the driver, the custom of IP address space is mapped to a virtual address, and then should be
Application to read data sent via the socket programming, found that passes through a data copy, and speed is too slow, excuse me, what is
Good plan, if use the DMA, what is the operating mode, thanks!
  • bhfletcher
    0 bhfletcher over 12 years ago
    Have you looked at the SDR training to see how that application is transferring data? It might not be the same application, but the principles may apply.
    http://www.microzed.org/support/trainings-and-videos
    Bryan
