Software Application Development link c++ Xilinx SDK
  • Subscribers 363 subscribers
  • Views 708 views
link c++ Xilinx SDK
I'm trying to figure out the c++ library linker settings for my Xilinx SDK project. Does anyone know which libraries i need to set to use c++?
Kind regards,
Bob
  • drozwood90
    0 drozwood90 over 12 years ago
    Hi Bob!
    When you made the new new project under the Project Explorer, did you choose C++ as your language?
    If you did, and you need access to setting the libraries, right click the project, under project explorer - choose "C/C++ Build Settings", then in the middle of the window under Tool Settings tab, you will see "ARM g++ linker".  In there you can set any libraries you will need to include.
    Knowing WHICH libraries need to be set, really depends on what libraries are required for the code you use.
    --Dan
    I have set up a c++ Project as standalone and I get linker Errors...
    [code]
    using namespace std;
    #include <stdio.h>
    #include <iostream>
    int main(int argc, char **argv) {
    tprintf ("asd");
    [/code]
    used tool chain is XILINX ARM GNU TOOLCHAIN
    in libraries there is nothing in it
    do I have to use the xilinx path?
    C:Xilinx14.7ISE_DSEDKgnuarm
    tarm-xilinx-eabilib
    and what are the necessary Parameters like
    -Wl,--start-group,-lxil,-lgcc,-lc,--end-Group
    thanks in advance
    PS: with XILINX ARM GNU TOOLCHAIN/Linux it builds without Errors but I can't run it on Hardware because it's standalone and It doesn't find any active device
    I solved this Problem creating a completely new Project worked fine for me
  • drozwood90
    0 drozwood90 over 12 years ago in reply to e14 Contributor
    blackout,
    Glad you got you worked it out!
    --Dan
