Software Application Development Petalinux Busybox configuration
  • Subscribers 363 subscribers
  • Views 2092 views
e14 Contributor over 8 years ago
Hi Experts,
I have a zedboard and i want to make and learn some applications with petalinux. I am using vivado 2018.1 and petalinux 2018.1 also. I want to change some busybox command outputs forexample ping command. Here is my standard ping output below.
root@avnet-digilent-zedboard-2018_1:~# ping 127.0.0.1
PING 127.0.0.1 (127.0.0.1): 56 data bytes
64 bytes from 127.0.0.1: seq=0 ttl=64 time=0.295 ms
64 bytes from 127.0.0.1: seq=1 ttl=64 time=0.104 ms
64 bytes from 127.0.0.1: seq=2 ttl=64 time=0.086 ms
64 bytes from 127.0.0.1: seq=3 ttl=64 time=0.089 ms
^C
--- 127.0.0.1 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.086/0.143/0.295 ms
But i want to change the output like below:
    printf("\n--- %s ping OEEE statistics ---\n"
        "%lu packets kursatgol transmitted, "
        "%lu packets KURSATGOL received, ",
        hostname, G.ntransmitted, nrecv
I found the the particular ping.c file from /home/kursatgol/Xilinx/projelerim/oeee_petalinux/components/yocto/downloads/busybox-1.24.1/networking/ping.c file and change the printf content like above than compile busybox via 'make' command. After this compiling i took the compiled final busybox executable file and applied referred http://www.wiki.xilinx.com/Build+and+Modify+a+Rootfs configurations. Extract initrd image like rootfs.ext4.gz and put in the busybox file and compress the rootfs.ext4 and save this compressed file to sdcard. But nothing change again.
Could you please help and advice on this issue?
Thank you very much and regards.
Kursat Gol
    0 e14 Contributor over 8 years ago
    Hi Zedboard Experts,
    Isn't there any comment about below or above issue as in good or bad? Could you please help me?
    Regards.
    Kursat Gol
    Please help me for a less an answer please. Really i need more help.
    thank you and regards.
    kursat
