Software Application Development implementing PWM by AXI Timer
  • Subscribers 364 subscribers
  • Views 1535 views
antony.kobin
antony.kobin over 9 years ago
hello
i am using z7020 SOC.
i want to get PWM signal from AXI Timer IP in vivado,
now i designed hardware and used xtmrctr.h lib in SDK, also i config PL frequency 50MHz, TCSR0 & TCSR1 0x00000206, TLR0 0x0EE6B27F and TLR1 0x0773593F.
i assigned w14 pin for PWM output.
Now, which functions from xtmrctr.h should be used for starting PWM output and TCSRs & TLRs registers in which function should be adjusted???
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    Which SOM are you using?
    Depending on which on, you might be using a pin already allocated for working with DDR memory.
    --Dan
  • antony.kobin
    0 antony.kobin over 9 years ago
    hi
    thank you very muck.
    but what's the SOM? please explain more details about this?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Antony,
    A SOM (System On Module) refers to the small board that is typicaly installed onto a Carrier Card. I believe it will be easier for convey if I show you some examples that we offer.
    http://zedboard.org/product/zynq-mmp
    http://zedboard.org/product/picozed
    http://zedboard.org/product/microzed
    http://zedboard.org/product/ultrazed-EG
    In your first statement you tell us that you are using a z7020 Soc, so Dans question is what board of ours are you using? Is it a ZedBoard, MicroZed, or PicoZed?
    --Josh
  • antony.kobin
    hi
    No, I'm using z-turn board.
    http://www.myirtech.com/list.asp?id=502
    could you please help me about this board?
  • jafoste4
    Hello Antony,
    Unfortunatly I can not offer assistance on products that are not our own. You could try asking for assistance over at the Xilinx Forum.
    https://forums.xilinx.com/
    It also appears that they have their own support system in place as well.
    http://www.myirtech.com/support.asp
    --Josh
