Software Application Development DMA Driver problem
  • Subscribers 363 subscribers
  • Views 623 views
DMA Driver problem
I am writing a driver for my application which use a DMA and XADC IP in PL and I have some problem.
I connected the Stream port of XADC IP on AXIS_S2MM port of DMA and I writed a driver.
When the driver is waiting for the transfert to complete :
timeout = wait_for_completion_timeout(&rx_cmp, timeout);
I have a time out (timeout = 0).
I tried with a loopback on AXIS_S2MM and AXIS_MM2S but I have the problem.
I compared my driver with an other that I found on Xilinx Forum ant they look like same.
Have you any why I have this problem ?
Jo
    I writed a simple program in order to read DMA register with /dev/mem :
    #include <stdio.h>
    #include <unistd.h>
    #include <stdlib.h>
    #include <fcntl.h>
    #include <string.h>
    #include <sys/mman.h>
    #define         DMA_BASEADDR            0xB0000000
    #define         MM2S_DMACR              0x0
    #define         MM2S_DMASR              0x4
    #define         MM2S_SA                 0X18
    #define         MM2S_LENGTH             0x28
    #define         S2MM_DMACR              0x30
    #define         S2MM_DMASR              0x34
    #define         S2MM_DA                 0X48
    #define         S2MM_LENGTH             0x58
    int main()
            int fd = 0, page_size = 0;
            unsigned int *dma_addr = NULL;
            if((fd = open("/dev/mem",O_RDWR)) < 1)
                    printf("Open failed
                    return 0;
            page_size = sysconf(_SC_PAGESIZE);
            dma_addr = (unsigned int*)mmap(NULL, page_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, DMA_BASEADDR);
            if(dma_addr == NULL)
                    printf("dma_addr failed
                    close(fd);
                    return 0;
            unsigned int reg = *(dma_addr + MM2S_DMACR / sizeof(unsigned int));
            printf("MM2S_DMACR 0x%08x
    ",reg);
            reg = *(dma_addr + MM2S_DMASR / sizeof(unsigned int));
            printf("MM2S_DMASR 0x%08x
    ",reg);
            reg = *(dma_addr + MM2S_SA / sizeof(unsigned int));
            printf("MM2S_SA 0x%08x
    ",reg);
            reg = *(dma_addr + MM2S_LENGTH / sizeof(unsigned int));
            printf("MM2S_LENGTH 0x%08x
    ",reg);
            reg = *(dma_addr + S2MM_DMACR / sizeof(unsigned int));
            printf("S2MM_DMACR 0x%08x
    ",reg);
            reg = *(dma_addr + S2MM_DMASR / sizeof(unsigned int));
            printf("S2MM_DMASR 0x%08x
    ",reg);
            reg = *(dma_addr + S2MM_DA / sizeof(unsigned int));
            printf("S2MM_DA 0x%08x
    ",reg);
            reg = *(dma_addr + S2MM_LENGTH / sizeof(unsigned int));
            printf("S2MM_LENGTH 0x%08x
    ",reg / sizeof(unsigned int));
            close(fd);
            return 0;
    And I have an unexpected result after starting the driver :
    S2MM_DMACR : 0x17003
    S2MM_DMASR : 0x0
    S2MM_DA : 0x0
    S2MM_LENGTH : 0x0
    MM2S_DMACR : 0x17003
    MM2S_DMASR : 0x0
    MM2S_SA : 0x0
    MM2S_LENGTH : 0x0
    I really lost, I don't what's going wrong the returns values of statues are set to zero.
    Jo
    Nobody can help me ?
    Jo
    Is it possible to have one VDMA and one DMA at the same time in the PL and use xilinx_vdma.c module for the VDMA and xilinx_axidma.c for the DMA ?
    Jo
    And if I use DMA controller in PS and I add a DMA IP in PL, is it going to work ?
    Jo
