Software Application Development error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file
  • Replies 10 replies
  • Subscribers 365 subscribers
  • Views 2126 views
I created Boot.bin file for developing xilinx-linux on ZedBoard(Digilent),
Then copied Boot.bin and other files(ramdisk,devicetree,Zimage,zynq_fsbl.elf) to sdcard and
Booted xilinux OS on Zedboard Successfully,
Then i tried to run the simple helloworld.c on this Xilinux-linux of Zedboard using the
ARM Crosscompiler's(arm-xilinux-linux-gnueabi-g++ helloworld.c -o A.out).
On Linux PC i genrated A.out file using the Arm crosscompiler's,then moved this A.out to Zedboard
and ran the A.out executable file xilinx-linux of Zedboard,it's giving helloworld o/p...working fine.
Now i am trying to running my c,c++ codes(more than 5 files) on Xilinux-linux of Zedboard,
For that one i genrated the A.out file on Linux PC using ARM cross compiler's,
Then i tried to ran the this A.out executable on xilinx-linux of ZedBoard.
it giving the following error,
error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
Then i tried to copied libstdc++.so.6 file to corresponding location on board side,
And also exported path for corresponding /bin and library files,
Still i am facing same problem,
Can Any one provide Solution for solving this error?
Can anyone help me in this please..?
    Compilation of user space applications is indeed difficult. The simplest solution is to compile your application natively on the board itself, as Xillinux includes gcc and make.
       Eli
  • zedhed
    0 zedhed over 13 years ago
    Hi mahesh418.g,
    Eli makes a great suggestion, native compiling on the target is definitely the way to go.
    If you are not able to go down that path for whatever reason, you should still be able to run C++ applications on ZedBoard using an OSL build.
    Take a look at our Linux on Zynq SpeedWay training.  We have hands-on labs that guide you through setting up a custom Root File System.  The lab that covers this is lab 2.2 and I have been running C++ applications on top of this RFS without the issues that you have been running into.  You are probably on the right track already in copying libstdc++.so.6 to /lib and setting up the appropriate symlinks to that library so your application can find it.
    -Kevin
    Thanks for ur reply....
    Now iam trying to running c,c++ codes on xilinx Linux of Zed-Board,Those are executing fine,
    But my codes having some hexadecimal input data,i want to move those to DDR memory loacation's of Zedboard usnig xilinux Linux OS,
    Can any provide some help for communicating the DDR of
    ZedBoard(on xilinux Linux) and provide sample links's for this Communication.
    I searched and tried some exaples on ZedBoard.org,this
    communication can done through using Standalone OS,In standalone OS,provided some API's,Macro's for this interaction with DDR of ZEDboard and Also some sample
    examples provided in Zedboard.org.
    Now same way i want to perform some RD/WR operations on DDR of Zedboard using xilinx Linux OS.....
    Can any one please suggest me for this DDR interaction through xilinx Linux....
    I attempted to answer this on the separate thread you started:
    http://www.zedboard.org/content/how-communicate-ddr-memory-locations-zedboard
      Eli
  • eactor
    0 eactor over 13 years ago in reply to e14 Contributor
    Is it really included on the sd card out of the box? On mine I can't find any gcc version? Is there a tutorial on how to get a native applicatin compiled?
    0 e14 Contributor over 13 years ago in reply to eactor
    The gcc compiler is included in Xillinux' image, yes. The compilation is just like on any UNIX machine, e.g.
    gcc -o hello hello.c
       Eli
  • eactor
    By Xillinx' image you are not talking about the original one from the SD card (BusyBox on ramdisk). So what do you refer to as Xillinux?
  • eactor
    Xillinux Download: http://xillybus.com/xillinux
  • eactor
    Hello I had a missing lib in helloworld example.
    It could be solved including it with gcc -static in.c -o out
    Or figuring out which lib is missing, with readelf -a within the Linaro Linux. For me it was a missing link between lib/ld-linux.so.3 to lib/arm-linux-gnueabihf/ld-2.15.so
    http://stackoverflow.com/questions/16935168/cross-compile-helloworld-for-arm/16941205#16941205
