Software Application Development Linux kernel version
  • Subscribers 363 subscribers
  • Views 547 views
e14 Contributor over 8 years ago
I've been running linux kernel 4.4.0 (xilinx-2016.1.01) for a long time on my microzed board.  Now I need to do something that requires a newer kernel, but no matter what kernel I use, it won't boot.  I'm using buildroot and I just change which kernel tag it pulls from Xilinx's github, merge over my kernel changes and config settings, flash the new uImage onto the board and it just hangs at the "Starting kernel ..." prompt.  I've tried kernel 4.6.0 (xilinx-2016.3) and kernel 4.9.0 (xilinx-2017.1).  I need at least kernel 4.6 but anything newer than that should be fine.  I don't know how I would go about debugging why the kernel doesn't start.
    0 e14 Contributor over 8 years ago
    Found the problem.  xilinx-v2016.3 adds efuse.c and a call to zynq_early_efuse_init() in common.c all in arch/arm/mach-zynq/ which means the devicetree needs an entry for an efuse.
    I added this to zynq-7000.dtsi and it boots:
     efuse: efuse@f800d000 {
                               compatible = "xlnx,zynq-efuse";
                               reg = <0xf800d000 0x20>;
