Software Application Development Ultra96 Boot Petalinux rootfs SD Card
  • Subscribers 363 subscribers
  • Views 1199 views
skukreti
skukreti over 8 years ago
I am trying to boot rootfs/ubuntu from a sdcard.
I built a custom Zynq Project in Vivado and created rootfs,kernel, u-boot using petalinux.
The bootargs are modified to mount root at /dev/mmcblk0p2
The SDCard is divided into two partitions.
1 GB Fat Partition(boot) and 14 GB ext4 partition(rootfs)
The BOOT.bin and image.ub end up in the boot partition. When the device is booted, I can get to the initramfs login but the kernel cannot find the SD Card.
u-boot complains of not being able to detect the SD Card but then it reads from the Fat partition.
sdhci@ff160000: 0 (SD)Card did not respond to voltage select!
What could be going wrong ?.
  • bhfletcher
    0 bhfletcher over 8 years ago
    Looks like others have seen similar errors:
    https://forums.xilinx.com/t5/Embedded-Linux/U-boot-boot-failure/td-p/451704
    https://forums.xilinx.com/t5/Embedded-Linux/U-Boot-fails-to-initialize-SD-card-on-ZCU102/td-p/876818
    Could you try changing the SD slot type to 2.0 in the vivado design and also check the SD Card speed?
    Bryan
  • zedhed
    0 zedhed over 8 years ago
    Hi skukreti,
    When you say "kernel cannot find the SD Card" what do you mean?  Does the mmcblk device not show up under /dev at all?
    Best Regards,
    -Kevin
