Software Application Development [Solved] questions about programable logic LED-brightness from trainings (Implementing Linux on the Zynq-7000 SoC)
  • Subscribers 364 subscribers
  • Views 631 views
in zedboard.org, Training&Videos, Implementing Linux on the Zynq-7000 SoC ,Lab 3.2
there is a training about how to control led-brightness in linux system.
it works well in that training.
yesterday I had a thought,add the led-brightness to zynq-zed-adv7511-xcomm configurations.
the kernel was downloaded from ananlog_devices_inc,and I add the files led-brightness need, 5 files:
drivers/Kconfig,
drivers/Makefile,
drivers/PL/Makefile,
drivers/PL/led-brightness.c,
driver/PL/Kconfig
(as what 0001-Xilinx-ARM-Driver-for-LED-brightness-device.patch says)
then I make menuconfig,make ARCH=arm
compile OK,no error,and it generate module led-brightness.ko in drivers/PL/
and I add
led-brightness@41200000 {
compatible = "avnet,led-brightness";
reg = <0x41200000 0x20>;
to zynq-zed-adv7511.dts ,then regenerate dtb file
the zImage can boot ,and the HDMI linaro-ubuntu desktop is OK,
when insmod led-brightness.ko,no error report.
but when run ./run-led-brightness 3
nothing happened to those 8 LEDs
why is that?
PS:I find the led-brightness.ko is 93.7kb.while in training use kernel linux-xlnx(zynq-zed-config,no adv7511support) is just 11kb.
  • zedhed
    0 zedhed over 13 years ago
    Hi double_crane,
    The driver work done in the SpeedWay training is based upon the hardware platform that was created in the Introduction to Zynq SpeedWay training.  In that training the custom PL peripheral is added to the PL hardware platform at address 0x41200000.
    Have you migrated that piece of the hardware platform in to your zynq-zed-adv7511-xcomm hardware platform?
    -Kevin
    0 e14 Contributor over 13 years ago in reply to zedhed
    I forget to add axi_gpio_0, make external, and so on.
    see Training&Videos---Zynq_Intro
    Lab04 -Adding_Custom_PL_Peripheral_14_2_2.pdf
    Hi: I want to obtain the document on avnet speedway implementing linux on the zynq-7000 to sduty the implementing linux on zedboard. Can you send it to me ? My email is "liusanjunbox1@126.com". I have bought a zedboard development board, and I am a teacher, so that I want to study this knowledge to teach my students. Thanks a lot.
    The Speedway material you request is available for download here:
    Implementing Linux on the ZynqRegistered-7000 All Programmable SoC (ISE 14.2)
    Keep in mind though that this material was developed with the Xilinx ISE tool suite and is a little dated. You might want to look at the newer Speedway: PetaLinux for the ZynqRegistered-7000 All Programmable SoC
    or take a look at the Silica Architech Yocto Community project for ZedBoard:
    http://zedboard.org/content/silica-architech-yocto-linux-zedboard-community-project-0
    -Gary
