Software Application Development Zedboard Reading from Block RAM
  • Subscribers 363 subscribers
  • Views 350 views
I am trying to read a block ram from the Zynq processor, through an AXI BRAM controller. The function Xil_In32() is what I am using, and it works, but my problem is I have to call that function with the base_addr of my block ram controller plus a multiple of 4. It is a 32-bit BRAM and when I read like this, I can't access addresses 1-3, only 0, 4, 8 and so on. If I try to access an address that is not a multiple of 4, the program halts. Anyone know how to work around this?
    I found the issue. Since we are using 32-bit width on the BRAM, we need to increment the address by 4 each write. Before I was reading whatever was the last value written to each address, hence 3, 7, 11, 15,...
    Now it writes to the proper location of the 32x8192 BRAM, and the Xil_In32() function reads the correct value from each location.
