Software Application Development Xilinux and IP Integrator
  • Subscribers 363 subscribers
  • Views 327 views
I am running Xilinux on my ZedBoard. I was excited to hear about IPI (IP Integrator) and making connections easy. However, I can not figure out how to, or if it is even possible, to make a block for the top module. I have made an IP core for the module I would like to add to Xilinux. Is there a way for me to use IPI, or must I go in and manually edit xillydemo.v to connect my IP core?
    The recommended method for integrating custom logic with Xillinux (and Xillybus in particular) is to manually edit xillydemo.v/vhd.
       Eli
