Software Application Development Need pre-build FPGA bit file
  • Subscribers 364 subscribers
  • Views 583 views
100sujay
100sujay over 10 years ago
I'm doing RF related project on picozed evaluation board.
Part Number:AES-PZSDRCC_FMC_G
Using below link i could compile AD9361 RF Non-OS driver source code;
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/no-os-setup
I am very new to FPGA, so feeling lot of difficulties to generate HDL from below link;
https://wiki.analog.com/resources/fpga/docs/build
I request you to send pre-build bit file for above board. So that i can test my software binary and atleast i can read product ID of the device through SPI.
Waiting for your prompt reply
Thanks and regards,
Suzz
  • jafoste4
    0 jafoste4 over 10 years ago
    Hi Suzz
    You can download a PicoZed FMC Carrier Card V1 Vivado hardware design in our reference design section
    http://zedboard.org/support/design/4701/76
    specifically the "Tutorial 01-04 Solutions" section, match your Vivado/PicoZed version to your setup. Then you will need to add either a PS or a PL SPI controller. Unfortunatly we do not have a PicoZed design that contains a SPI controller. We have an example of implementing a SPI controller for our MicroZed IIOT kit that you could reference in implementing your SPI controller in your design.
    http://zedboard.org/support/design/13591/116
    --Josh
  • mbrown
    0 mbrown over 10 years ago
    Hello Suzz,
    If you want to get started using PicoZed SDR without using Xilinx Vivado, your best bet is use the SD card boot image.
    https://wiki.analog.com/resources/tools-software/linux-software/zynq_images
    If you want to rebuild the Vivado project and generate a bitstream, it's even easier now. See this forum post:
    http://picozed.org/content/how-do-i-rebuild-reference-design-hdl-project
    The PicoZed SDR Getting Started Guide has all of this info.
    /Matt
  • maisoncorners
    0 maisoncorners over 9 years ago
    All the needed files are here - https://these-guys-can.com/ as I checked them for usability. Last year, I uploaded them to the directory and they are still ok. Perhaps, they can be helpful.
