Software Application Development USB storage using bare metal application On Zedboard
  • Subscribers 366 subscribers
  • Views 2592 views
monali
monali over 9 years ago
  It seems many people have tried to access USB storage device connected to Zynq PS externally, through bare metal application. But unfortunately I could not get any solution on it. We are trying the same again.
We could initialise USB storage device trough bare metal application, but unable to get its interrupt event so that we can start storage.
We are using Zedboard
Tool : SDK 2015.4
We cannot move to linux as we have other limitations. If anyone has gone beyond initialising USB trough bare metal, please provide some direction.
Or is it like it is very difficult to implement USB storage in bare metal?
Thank you
Monali
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Monali,
    Have you looked at the usb and usbps examples located in SDK located at
    C:\Xilinx\SDK\2016.4\data\embeddedsw\XilinxProcessorIPLib\drivers
    to see if any of them cover what you are trying to do?
    --Josh
  • monali
    0 monali over 9 years ago in reply to jafoste4
    Hello
    Yes, we have checked the usbps examples. Most of them are configuring USB device as HID or as Slave device. we want to configure ZYNQ device as host and to store streaming data through VDMA S2MM channel  to PS DDR and from DDR to slave device ( USB mass storage device ).
  • monali
    Hello Josh,
    Will you please check this link once.
    http://www.wiki.xilinx.com/Zynq+Standalone+USB+device+driver
    It says HOST and OTG mode are not supported by standalone drivers. But it is stated as limitation to the driver. Does that mean it is not at all possible to implement OTG mode using standalone drivers.
    Thanks and Regards,
    Monali
  • zedhed
    0 zedhed over 9 years ago
    Hi Monali,
    Use of the USB interface has been best supported under Linux.  It should be possible to get it working under standalone, but I am guessing that you would spend a lot of development work to get it to the point where you can enumerate client devices and move data in the direction you want.
    You are correct, HOST and OTG functionality are not supported by the standalone drivers since you need different USB stack functionality for those modes.
    Have you looked into Micrium RTOS?
    http://www.wiki.xilinx.com/uCOS
    Micrium also has a USB host stack that works with the Xilinx EHCI controller.
    https://www.micrium.com/rtos/usbhost/
    -Kevin
  • lelee007
    0 lelee007 over 8 years ago
    https://gitenterprise.xilinx.com/embeddedsw/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/usbps/
    why this link can't be accessed right now? and where could it be downloaded? thanks.
  • jafoste4
    0 jafoste4 over 8 years ago
    I don't know what that link goes to, however i think your trying to access the xilinx github.
    https://github.com/Xilinx
    -Josh
