Software Application Development why peripheral test project turn out work failed ?
  • Subscribers 363 subscribers
  • Views 688 views
I build a new "Peripheral Test" project and launch it at my zedboard, but it stoped at  the 2th interrupt test.
This is the output information of console in SDK:
   ---Entering main---
   Running ScuGicSelfTestExample() for ps7_scugic_0...
   ScuGicSelfTestExample PASSED
   ScuGic Interrupt Setup PASSED
   Running Interrupt Test  for ps7_ethernet_0...
The application stopped at "interrupt test for ps7_ethernet_0".
I try to test ScuTimerIntrExample at the 2th order and this is the output:
   ---Entering main---
   Running ScuTimerPolledExample() for ps7_scutimer_0...
   ScuTimerPolledExample PASSED
   Running Interrupt Test  for ps7_scutimer_0...
It stopped at the interrupt test for scu timer as predicted.
Actually , i have test gpiops interrupt function but failed. i have studying the interrupt of zynq for such a long time but no work come out. i am depressed, help me. thanks a lot.
  • bhfletcher
    0 bhfletcher over 13 years ago
    What version of ISE tools are you using? Have you been through the CTT tutorial?
    Bryan
    0 e14 Contributor over 13 years ago in reply to bhfletcher
    SDK 14.5. i have done some tuorials already. everything goes fine except the interrupt test.
    recently i test the "Peripheral Test " Project again, but it works fine:
    ---Entering main---
    Running QspiSelfTestExample() for ps7_qspi_0...
    QspiPsSelfTestExample PASSED
    Running DcfgSelfTestExample() for ps7_dev_cfg_0...
    DcfgSelfTestExample PASSED
    ScuTimerIntrExample PASSED
    Running Interrupt Test  for ps7_scuwdt_0...
    ScuWdtIntrExample PASSED
    ---Exiting main---
    why, i have done nothing, is it the reason of SDK?
    what if it happens next time?
    hope someone can explain why. thanks.
  • bhfletcher
    I have seen some strange things with Java, Windows Firewall, and also JTAG. Perhaps after you went through it once, you had everything set up to run smoothly the 2nd time around.
    Bryan
