Software Application Development wilink 8 build error
  • Subscribers 363 subscribers
  • Views 531 views
hi.
i can not build wilink script
i use petalinux 2014.4 version (xlnx-3.17)
step 1.
/build-utilites$ ./sudo_build_wl18xx.sh init
step 2.
/build-utilites$ ./sudo_build_wl18xx.sh patch_kernel
step 3
petalinux-build
step 4 (Error)
/build-utilites$ ./sudo_build_wl18xx.sh update R8.6 (or R8.6_SP1)
y original source files ...
Applying patches from patches to /home/jkpark/wilink/build-utilites/src/compat_wireless ...
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
Generating local configuration database from kernel ... done.
cc -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer   -c -o conf.o conf.c
as: unrecognized option '--64'
make[2]: *** [conf.o] Error 1
make[1]: *** [defconfig-wl18xx] Error 2
make: *** [defconfig-wl18xx] Error 2
| Your backport package isn't configured, please configure it
| using one of the following options:
| To configure manually:
|     make oldconfig
|     make menuconfig
| To get defaults for certain drivers:
|     make defconfig-alx
|     make defconfig-ar5523
|     make defconfig-ath10k
|     make defconfig-ath5k
|     make defconfig-ath6kl
|     make defconfig-ath9k
|     make defconfig-ath9k-debug
|     make defconfig-b43
|     make defconfig-b43legacy
|     make defconfig-brcmfmac
|     make defconfig-brcmsmac
|     make defconfig-carl9170
|     make defconfig-cw1200
|     make defconfig-hwsim
|     make defconfig-igb
|     make defconfig-iwlwifi
|     make defconfig-nfc
|     make defconfig-rtlwifi
|     make defconfig-wcn36xx
|     make defconfig-wifi
|     make defconfig-wil6210
|     make defconfig-wl18xx
|     make defconfig-wwan
make[2]: *** [.config] Error 1
make[1]: *** [modules] Error 2
make: *** [default] Error 2
****** ERROR 0 *******
setup-env
#                           -(o o)-
#========================oOO==(_)==OOo=======================
# This file contains the exports needed for automating the
# build process of WLAN components.
# Place this file in the same directory with wl18xx_build.sh
# build scripts. No need to run 'source setup-env', the build
# scripts will perfom it internaly.
# User specific environment settings - use full PATH
# if DEFAULT toolchain path is set toolchain will be downloaded to ./toolchain.
export TOOLCHAIN_PATH=/opt/Xilinx/SDK/2015.4/gnu/arm/lin/arm-xilinx-linux-gnueabi/bin
# if DEFAULT path to root filesystem is set ./fs folder will be used.
export ROOTFS=/home/jkpark/petalinux20144/test/fs
#if DEFAULT kernel path is set - kernel will be downloaded (set branch to match kernel version)
export KERNEL_PATH=/home/jkpark/petalinux20144/test/build/linux/kernel/xlnx-3.17
#export KERNEL_PATH=/home/jkpark/temp/wl18xx
# if KERNEL_VARIANT below is set the build script will look for kernel specific
# patches under the patches directory:
# - patches under the pathces/driver_patches/$KERNEL_VARIANT directory would be
#   applied during "modules" build.
# - patches under the patches/kernel_patches/$/$KERNEL_VARIANT directory would
#   be applied to the kernel pointed by KERNEL_PATH in case the "patch_kernel"
#   command is used.
#   Note: the kernel is not built automatically after the patches are applied
export KERNEL_VARIANT=xlnx-3.17
export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
export ARCH=arm
[ "$TOOLCHAIN_PATH" != "DEFAULT" ] && export PATH=$TOOLCHAIN_PATH:$PATH
  • bhfletcher
    0 bhfletcher over 10 years ago
    Have you already viewed these topics?
    http://picozed.org/content/steps-get-wlink-using-petalinux-microzed
    http://zedboard.org/content/steps-get-wlink8-working-using-petalinux-picozed
    Bryan
    0 e14 Contributor over 10 years ago in reply to bhfletcher
    i already viewed two link topics.
    but i can not build wilink script.
