Software Application Development Problems debugging in XSDK 2015.2
  • Subscribers 362 subscribers
  • Views 225 views
jesusmgonzalez
jesusmgonzalez over 11 years ago
Recently I started a new project in Vivado 2015.2, and exportes succesfully the code to XSDK 2015.2. I generate the bsp and import the source code I'd like to debug.
The problem begins when I try to debug with standard GDB: no source code is avaiable to debug, and a message -No source available for "" - appears.
Does anybody know what's wrong?
I select correctly the corresponding .elf and debug options (otherwise error messages would be prompted).
Thanks!
  • bhfletcher
    What hardware are you targeting? Which JTAG cable are you using? Have you tried debugging one of the applications that can be generated within SDK, like the Peripheral Test?
    Bryan
