Software Application Development Creation of files in directory/folder using xsdps driver of BSP
  • Subscribers 363 subscribers
  • Views 827 views
I am using SD card application in my project, I have created standalone project and enabled Sdps in BSP.
I am able to create a directory using f_mkdir(const T_CHAR *path);.
I want to create files inside a directory, but there is no standard function to do so.
Please help me in creation of files inside the directory.
Praneeth
    Hello Praneeth,
    I would start by looking at the Xilinx Xil FFS library functions and the FatFS file system if you want to implement a 'bare metal' file system:
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/oslib_rm.pdf
    http://elm-chan.org/fsw/ff/00index_e.html
    This forum thread might be useful as well:
    http://zedboard.org/content/standalone-sd-card-sdio
    -Gary
    Hello Gary,
    Thanks for the reply, I am using the functions listed by elm-chan.org, but there is no function or an API to write files inside a directory.
    Praneeth
    Hello Praneeth,
    I have not used the FatFS file system myself, but I see API calls to 'change current directory', 'open directory' , 'open/create file', and to 'write data'. What other API would you need?
    -Gary
    Hello Gary,
    I am able to create a directory. Open a file and write to a file outside the directory.I have also tried opening a directory using f_mkdir and f_opendir, but when I create a file after f_opendir function, it is exiting from the function. My application requires creating files inside a Directory. But it is happening separately.
    Praneeth
