Software Application Development AXI Ethernet driver can't send packets
  • Subscribers 363 subscribers
  • Views 975 views
Hi all,
I use 4 AXI Ethernet Subsystem connected with 4 AXI DMA.
And I connect Ethernet FMC to my zedboard,
I can send packet by Ethernet FMC to my switch in JTAG mode
so, the hardware design is correct.
I use Ethenert FMC on Zedboard in Linux environment.
I can see eth1 ~ eth4 when I command ifconfig in Linux environment , but can't ping to my lab switch( ex : ping 192.168.1.1 )
Does anyone know why axi ethernet driver can't work ?
My axi ethernet driver downloaded from the website(digilent github) :
https://github.com/Digilent/linux-digilent/tree/master/drivers/net/ethernet/xilinx
( not  -> https://github.com/Xilinx/linux-xlnx/tree/master/drivers/net/ethernet/xilinx )
My FPGA design is from https://github.com/fpgadeveloper/zedboard-qgige-axieth
    If you are using multiple ethernet devices under Linux, you will need to make changes to the device tree to properly connect the drivers to the respective hardware components.  There should be an entry for each of the ethernet devices.
    Ron
    Hi Ron,
    Thanks for ur reply.
    My devicetree is generated by SDK 2014.4,
    Could you help me to check where is the error in my devicetree
    Thank you :))
    And sorry for I posted the wrong website of my driver
    My driver is downloaded from(digilent github)
    Sincerely,
    Louis
    Hi Louis,
      I'll send you a message directly to see if we can get to the bottom of this.
    Ron
