Software Application Development Spi dev as SLAVE
  • Subscribers 363 subscribers
  • Views 2207 views
Spi dev as SLAVE
robert.burczyk94
robert.burczyk94 over 8 years ago
How can I configure SPI DEV in Zedboard (PS side) as a SLAVE mode? Do I have to add some entries to dts file (devicetree) to configure it as a slave or have to add some entries in kernel configuration (defconfig)? How can I do it? Do you have some exaple device tree files where is SPI configured as SLAVE?
Thanks for help, Robert
  • bhfletcher
    0 bhfletcher over 8 years ago
    I think the following topics might be helpful.
    https://forums.xilinx.com/t5/Xcell-Daily-Blog-Archived/Adam-Taylor-s-MicroZed-Chronicles-Part-217-SPI-for-the-Zynq-SoC/ba-p/796622
    https://forums.xilinx.com/t5/Welcome-Join/Use-SPI-PS-and-I2C-PS-as-Slave-on-SDK-Zynq-7020/td-p/747477
    https://forums.xilinx.com/t5/Embedded-Linux/Support-for-interbyte-delay-in-SPI-transfers-in-Zynq/td-p/757955
    https://forums.xilinx.com/t5/Embedded-Linux/how-to-use-zynq-spi0-as-master-communicate-with-spi1-as-slave/td-p/802509
    Bryan
  • robert.burczyk94
    0 robert.burczyk94 over 8 years ago
    Thanks for help. In my kerler configuration i added some entries:
    CONFIG_SPI_SLAVE=y
    CONFIG_SPI_SLAVE_TIME=y
    CONFIG_SPI_SLAVE_SYSTEM_CONTROL=y
    that enabled spi_slave class in /sys/class. Now, I have to edit device tree, but in /dev/ isn't exist apriopirate device and /sys/class/spi_slave is empty. This is my device tree configuration:
    zynq-7000.dtsi :
    spi1: spi@e0007000 {
       compatible = "xlnx,zynq-spi-r1p6";
       reg = <0xe0007000 0x1000>;
       status = "disabled";
       interrupt-parent = <&intc>;
       interrupts = <0 49 4>;
       clocks = <&clkc 26>, <&clkc 35>;
       clock-names = "ref_clk", "pclk";
       #address-cells = <1>;
       #size-cells = <0>;
    zynq.dtsi :
    &spi1 {
            spi-slave;
     status = "okay";
  • robert.burczyk94
    Could you tell me what I did wrong? :) Thanks, Robert
  • robert.burczyk94
    Hello, I know why it doesn't work properly. Entry: compatible = "xlnx,zynq-spi-r1p6"; applies to the controler spi-cadence.c. This controller support onlu SPI MASTER mode, not SPI slave mode. I was looking for a long time, but I didn't find the controller that support SPI SLAVE mode too. Maybe one of you knows a controler with slave mode support? Thanks for help! Robert
  • bhfletcher
    0 bhfletcher over 8 years ago in reply to robert.burczyk94
    I am not sure. Since you are referencing a piece of Xilinx IP, will you please try putting your question on the Xilinx Forum?
    Bryan
  • robert.burczyk94
    There is no a SPI controler that support the slave mode
