Software Application Development Pulsar Serial port settings
  • Subscribers 364 subscribers
  • Views 450 views
nick0559
nick0559 over 10 years ago
The getting started guide for Pulsar does not mention an important point.  What should the serial port be set to to talk to the board?
Can someone supply this information?
Nick
  • jafoste4
    0 jafoste4 over 10 years ago
    Hello Nick,
    The Serial port setup should be as follows
    Port: - (Your active COM  port)
    Baud rate - 115200
    Data - 8 bit
    Parity - None
    Stop - 1 bit
    Flow control - none
    --Josh
  • jeniffermurphy
    0 jeniffermurphy over 9 years ago
    Pulsar serial port set:
    To get data from your GSM modem, interface the modem to a serial correspondences port on your PC or Tablet.
    Select the right port in the correspondences port setup screen and guarantee the baud bate = 19200 bps.
    Open another database by choosing the Record menu and picking "New Database".
    Give it a name pick "Open".
    To construct the database, tap on the stations data tab and snap auto or manual output. The database will naturally refresh itself when a message is gotten from the modem and sorted in light of the site recognizable proof of the unit sending the message.
    Hope this helps, type my essay for me to let me know if you managed to deal with the set.
