Software Application Development Linux USB Device
  • Subscribers 363 subscribers
  • Views 668 views
Linux USB Device
Hi guys!
I'm currently trying to make the zedboard appear as a USB device for my host computer (running W7 and Ubuntu12.04).
I have tried with both the most recent kernel from Xilinx and with the kernel from Analog Devices from their reference design(3.3 I think).
I have been able to compile down modules for g_mass_storage, g_file_storage, g_hid etc...
I would be perfectly happy as soon as the zedboard enumerates correctly... The Gadgets have been compiled to modules and after power on for the board, I try to load the g_mass_storage module with args:
modprobe g_mass_storage file=/str/something
This command works fine, and gives the following dmesg output:
g_mass_storage gadget: controller 'xusbps-udc' not recognized
g_mass_storage gadget: Mass Storage Function, version: 2009/09/11
g_mass_storage gadget: Number of LUNs=1
lun0: LUN: removable file: /str/backing_file
g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
g_mass_storage gadget: userspace failed to provide iSerialNumber
g_mass_storage gadget: g_mass_storage ready
xusbps-udc: bind to driver g_mass_storage
However, that is where my luck ends... Trying to insert it into one of my host PCs is not very successful, my Ubuntu gives the following output in dmesg:
[2415.212220]usb 2-5: new high-speed USB device number 7 using ehci hcd
[2415.282304]hub 2-0:1.0 unable to enumerate USB device on port 5
[2415.544223]usb 2-5: new high-speed USB device number 8 using ehci hcd
[2415.614193]hub 2-0:1.0 unable to enumerate USB device on port 5
[2415.876221]usb 2-5: new high-speed USB device number 9 using ehci hcd
[2415.946815]hub 2-0:1.0 unable to enumerate USB device on port 5
Anyone having succeeded in creating an USB device?
    Furthermore, it seems like the gadget is loaded properly but then oscillates between suspend and resume-states, my dmesg-output is crowded with:
    g_serial gadget: resume
    g_serial gadget: suspend
    and so on...
    Anyone having any ideas as to why and/or how to fix it? Or know where to search for information? Tried googling, but no luck yet...
    And on another topic, there seem to be something wrong with xusbps-driver, since it gets a null-pointer exception when unloading modules... Will look into it further tomorrow...
    Ok, found un-registring problem and fixed it. Inside the IFDEF for OTG in udc-driver there is an unconditional setting of two pointers. However, they may be NULL if a gadget is non-otg. Fixed by surrounding those two lines with:
    if (gadget_is_otg(&udc_controller->gadget)) {
    tudc_controller->xotg->start_peripheral = NULL;
    tudc_controller->xotg->stop_peripheral = NULL;
    Hope it helps someone.
    However, not closer to solving why gadgets gets resumed/suspended .......
    Further information about the problem... When loading a module and plugging the cable into a host, it seems like only three types of interrupts ever appear... its
    xusbps-udc: bind to driver g_serial
    USB irq is : 100
    Suspend_irq
    irq_src & usb_sts_suspend
    USB irq is : 40
    bus_resume
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 100
    Suspend_irq
    USB irq is : 40
    bus_resume
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 100
    Suspend_irq
    USB irq is : 40
    bus_resume
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 100
    Suspend_irq
    USB irq is : 40
    bus_resume
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    USB irq is : 40
    USB irq is : 4
    (0x4, 0x40 and 0x100) which are called:
    #define  USB_STS_PORT_CHANGE 0x00000004
    #define  USB_STS_RESET       0x00000040
    #define  USB_STS_SUSPEND     0x00000100
    starting with a suspend... Does this point towards a hw-fault? or is it something wrong in the driver?
    Hi, I'd like to make the zedboard visible as device using USB but  I've not been able to do this. I've done some test but without success. The strange issue is that the driver seems not receive any event when I plug/unplug the USB cable.
    Any suggestion on how proceed. There is any specific kernel version where you have tested this functionality?
    Thanks in advance,
    Manuele
