Software Application Development Can't start my  binary under Linaro
  • Subscribers 363 subscribers
  • Views 532 views
I have a system with Digilent kernel and Linaro ALIP filesystem. Then I compile a Hello World using the Xilinx toolchain, and produce a binary named as zed_led_test.elf. I upload the resulting binary to the target, and try to start it from the command line. But the shell says:
root@linaro-alip:/home/linaro/bin# ./zed_led_test.elf
-bash: ./zed_led_test.elf: No such file or directory
Then I install GDB on the target and run "gdb zed_led_test.elf":
Reading symbols from /home/linaro/bin/zed_led_test.elf...done.
(gdb) run
Starting program: /home/linaro/bin/zed_led_test.elf
/bin/bash: /home/linaro/bin/zed_led_test.elf: No such file or directory
During startup program exited with code 127.
What could be the problem?
    e14 Contributor over 13 years ago +1
    Here's what to do. As root on the target, go to /lib and ln -s arm-linux-gnueabihf/ld-linux-armhf.so.3 ld-linux.so.3 See http://ubuntuforums.org/showthread.php?t=2031471 Could be that I should have installed…
    Could be that I should have installed a more recent Linaro filesystem.
    I am trying to run application on my Zedboard. Until now what I have achieved is to run Linaro Ubuntu on my ZEdboard.
    I would like to kindly ask you how did you generate you .elf  file? ... perhaps using xsdk? I am confused because I thought only baremetal applications can run .elf executables.
    Any guideline would be appreciated, many thanks!
    Leo
