Software Application Development PetaLinux BSP for UltraZed-EG Starter Kit
  • Replies 19 replies
  • Subscribers 368 subscribers
  • Views 4717 views
mark.suska
mark.suska over 9 years ago
Where can I download the PetaLinux BSP for the UltraZed-EG Starter Kit?
  • narrucmot
    narrucmot over 4 years ago in reply to dyessgg +1
    We are working on the 2021.2 BSPs now. They won't be much different from the 2021.1 BSPs (same Linux kernel, same underlying yocto, etc.) that were announced here: /technologies/fpga-group/b/blog/posts…
  • mark.suska
    0 mark.suska over 9 years ago
    What is the  ZED BSP found on Xilinx site? Is this what I need for to reproduce the Out-Of-Box (OOB) for the UltraZed-EG Starter Kit?
    https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2016-4.html
  • mark.suska
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello mark,
    You can find the UltraZed SOM+IO Carrier Card BSP located here http://zedboard.org/support/design/17596/131
    Currently we only have the 2016.2 version available, we are in the process of updating it.
    The ZED BSP you found is the Petalinux BSP that targets the ZedBoard hardware.
    --Josh
  • mark.suska
    0 mark.suska over 9 years ago in reply to jafoste4
    Thanks Josh.
    Do all the software versions have to be the same? i.e.:
    •   Vivado SDK 2016.2
    •   UltraZed Board Definition files 2016.2
    •   PetaLinux 2016.2
    •   UltraZed SOM+IO Carrier Card BSP 2016.2
    Or, can I use the latest version of Vivado SDK with the latest UltraZed Board Definition files (which seem to be 2016.4) and will it work with older PetaLinux? i.e.:
    •   Vivado SDK 2017.1
    •   UltraZed Board Definition files 2016.4
    •   PetaLinux 2016.2
  • jafoste4
    Hello Mark,
    I would always suggest for you to have the same software versions. In some cases mismatching various software versions has caused some issues.
    --Josh
  • xsteve
    0 xsteve over 9 years ago in reply to jafoste4
    Any news on the BSP update process?
    I have to use 2017.1 for my project.
    I am able to build the Linux Image fro 2016.2. But it fails when I try to use the 2017.1 SDK together with the 2016.2 BSP
    Can you give a hint when the 2017.1 BSP will be available?
      Stefan.
  • irislee@baidu.com
    0 irislee@baidu.com over 9 years ago in reply to xsteve
    I'm waiting for 2017.1 BSP also as 2016.2 BSP didn't work with 2017.1 SDK and Petalinux.
    Can it be available soon?
    Iris
  • jafoste4
    0 jafoste4 over 9 years ago in reply to irislee@baidu.com
    Hello Iris,
    We are still working on the BSPs, sorry about the delay.
    --Josh
  • jafoste4
    The 2017.2 BSP has been posted for both UltraZed IO Carrier Card and PCIE Carrier Card.
    --Josh
    0 e14 Contributor over 8 years ago
    Hello, are there any plans for 2018.2 BSP upgrade?
