Software Application Development Zedboard debug with Virtualbox
  • Subscribers 363 subscribers
  • Views 379 views
I am running the Xilinx SDK in Ubuntu 14.0.2 in Virtualbox (Windows 10 host) building a bare-bones Zedboard application. I cannot get the debugger to work. I get the "could not find ARM device on board for connection 'Local'.
In Virtualbox, I am sharing the "Diligent USB Device [0900]" (which I believe is the USB-JTAG) and "2012 Cypress Semiconductor Cypress-USB2UART" devices with the guest Linux machine. (The USB serial does share since I can use minicom to see the Linux terminal.)
GDB over TCP/IP (ssh) is not an option because I'm doing barebones development.
Has anyone else been able to debug in Virtualbox with the USB-JTAG?
Any suggestions?
Thank you.
  • zedhed
    0 zedhed over 9 years ago
    Hi rubinstu,
    Getting USB interfaces working under Virtual Box has been very tricky but I think that was the USB-UART that we were successful with and not the USB-JTAG.  Typically USB-JTAG is used on a Windows PC with a Vivado install.  That being said, it may not be impossible to get USB-JTAG working under a Virtual Machine...
    Can you please try the suggestion in this Xilinx AR and see if that resolves your issue:
    https://www.xilinx.com/support/answers/59128.html
    Also came across this as well which indicates that a separate driver install must be performed:
    https://github.com/Architech-Silica/Installing-Vivado-2015.1-Ubuntu-14.04.2-64b
    -Kevin
