Software Application Development Can't install libm on ZedBoard running Xillinux
  • Subscribers 364 subscribers
  • Views 360 views
I wanted to compile a simple C program with mathematical functions and found out that libm is missing.
How can I install it?
I am using a ZedBoard running the latest Xillinux version (which is Ubuntu 12.04).
I need this for my bachelor thesis and running short on time.
Thank you in advance
  • zedhed
    0 zedhed over 12 years ago
    Hi DenHir,
    In my Xilinx SDK 2014.2 install folder I found a libm.a and libm.so located in the folder C:XilinxSDK2014.2gnuarm
    tarm-xilinx-linux-gnueabilibcusrlib
    Can you simply link to this library when building your application and simply copy it over to your Xillinux root file system?
    -Kevin
    Mixing binary libraries isn't such a good idea usually, and libm is so basic that any distribution has it, including Xillinux of course.
    Since the OP turned to Xillybus' support as well, it was resolved there: It turned out that there was an issue with the Makefile; the -lm flag was given at the wrong command. limb wasn't missing, as originally thought.
       Eli
