Software Application Development SPI Controller C Code Example
  • Subscribers 364 subscribers
  • Views 1699 views
Hi, I'm using SPI from Zynq PS (XSPIPS). I'm looking for a C code example in order to use the SPI controller.
Thanks!
  • zedhed
    0 zedhed over 11 years ago
    Hi dannna,
    Have you taken a look at the example code provided with the SPIPS driver under SDK?  For SDK 2014.4, those examples are located in the following folder:
    C:XilinxSDK2014.4dataembeddedswXilinxProcessorIPLibdriversspips_v1_06_aexamples
    -Kevin
    You may also want to take a look at the code in the Maxim Santa Fe reference design (MAXREFDES#5) for the MicroZed Board:
    http://www.maximintegrated.com/en/design/reference-design-center/system-board/5561.html/tb_tab2
    It has code for the PS SPI controller.
    I will also mention that, depending on your application, you may want to consider using the AXI Quad SPI controller. It is more flexible than the PS SPI controller if you have the space in your Programmable Logic section.
    -Gary
