Software Application Development Global or Private Timer
  • Subscribers 363 subscribers
  • Views 493 views
I need some help for using private or global timers to compute execution time of a function, also please help me who to compute time
Thank You
    Hello Mohammad,
    You might want to consider using the option to profile a software application within the SDK.  Users Guide 1165, the Zynq Embedded Design Tutorial, has instructions on how to use the profiler.
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug1165-zynq-embedded-design-tutorial.pdf
    -Gary
    Hello Gary
    thanks for your help, but i actually need to get results from my own software, I get values from global timer but I don't know how to convert it to ms.
    Per the Zynq Technical Reference Manual, UG585, (look at chapter 8) the global timer is a 64 bit auto incrementing timer that is clocked at 1/2 of the CPU clock rate. For most Zynq boards that would be 333 MHz.
    The TRM can be found here: http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
    -Gary
