Software Application Development building from scratch
  • Subscribers 363 subscribers
  • Views 372 views
Hi:
I am planning to use the zedboard for our new project and I want to build the image from the scratch, so is there any guide about building the pre-loader,u-boot, kernel etc. I want to start from Ubuntu and build the image from scratch.
Tushar
    Hi Tushar
    Have a look here:
    http://www.wiki.xilinx.com/Getting+Started
    Cheers, Sam.
    It is possible, and I've done it, unfortunately my notes weren't very good. The link Sam gave above mostly worked for me, here are the few notes I took:
    - Get the buildroot/busybox .configs from the Xilinx site, but go through them in detail-- I found at least one hard-coded path to a Xilinx developer's workspace you'll have to replace with your own setup (I think it was to the directory where the arm-xilinx-linux-gnueabi- tools are installed).
    - If you're creating an FPGA image, synthesis will fail (I think this is Ubuntu specific) because the tool can't call gmake-- just symlink it to make.
    - (Good general advice) Be sure to "make clean" before actually "make"ing any given project. At least one of them had an old configuration that messed up my build because I didn't make clean first.
    Right now it is just on the microzed, but I plan on adding zed support next week.
    No fsbl required. It uses u-boot's spl features to generate the boot.bin file. (Xilinx fsbl is not open source, and it is a pain in the ass to use)
    100% open source and should build under any linux distro, though I've only tested building it on ubuntu.
    http://www.vxmdesign.com/zynq.html
    -Chris
