Software Application Development The remote CPU can't get interrupt by GPIO ps on FreeRTOS
  • Subscribers 363 subscribers
  • Views 463 views
aersean
aersean over 9 years ago
I have a ZYNQ-7030 Dev-board. CPU0 and CPU1 communicate with OpenAMP. CPU0 is on Petalunix, and CPU1 is on FreeRTOS.
Now GPIO ps pin No. 51 link a switch. When the switch is pressed, I want to sample a data on CPU1, and then the data is sent to CPU0.
So I add a Switch device into device tree:
gpio-keys {
    compatible = "gpio-keys";
    #address-cells = <1>;
    #size-cells = <0>;
    sw2@51 {
        label = "sw2";
        interrupt-controller;
        #interrupt-cells = <2>;
        gpios = <&gpio0 51 0>;
        gpio-key,wakeup;
        linux,can-disable;
And code into FreeRTOS:
      // Init Button Pin status
      XGpioPs_SetDirectionPin(&psGpioInstancePtr, GpioPsPinNum_Btn, 0); //MIO pin direct
      XGpioPs_SetIntrTypePin(&psGpioInstancePtr,GpioPsPinNum_Btn, XGPIOPS_IRQ_TYPE_LEVEL_HIGH);
      XGpioPs_SetCallbackHandler(&psGpioInstancePtr, &psGpioInstancePtr, ISR_GpioPsBtn);
      XGpioPs_IntrEnablePin(&psGpioInstancePtr,GpioPsPinNum_Btn);
   void ISR_GpioPsBtn(void *CallBackRef, u32 Bank, u32 Status)
   XGpioPs *pXGpioPsPtr = (XGpioPs *)CallBackRef;
   XGpioPs_IntrDisablePin(pXGpioPsPtr, GpioPsPinNum_Btn);
   XGpioPs_IntrEnablePin(pXGpioPsPtr, GpioPsPinNum_Btn);
   But, the ISR can't be called. Please help found the issue, Thank!!
   Beat regards,
   Aersean
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Aersean,
    Could you point me to which instructions you are following to configure Linux and FreeRTOS in the manner you described above.
    Josh
