Software Application Development building a kernel module/device driver for zedboard/zynq
  • Subscribers 364 subscribers
  • Views 678 views
I have a PL design to which I need to write my own char device driver to control. I did the driver development on my linux VM and have a standard kernel module makefile
obj-m += mydriver.o
mydriver-objs := my_driver.o
all:    make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
        make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
however when I go to build it on my zedboard linux install (Linaro) i get this error:
make: *** /lib/modules/3.18.0-xilinx-06444-g06af32c/build: No such file or directory.  Stop.
make: *** [all] Error 2
how may I go about building my driver on zynq?
  • zedhed
    0 zedhed over 11 years ago
    Hi BluePAZ,
    Are you compiling your driver statically into the kernel image?
    When I add a new PL driver to the kernel, I typically put it in a new drivers/pl/ folder under the kernel source.
    Then I make edits to drivers/Kconfig to add the Kconfig from my PL driver:
    source "drivers/pl/Kconfig"
    Then I make edits to drivers/Makefile to add the PL driver directory to the build traversal list:
    obj-$(CONFIG_PL)tt+= pl/
    Then I edit the PL driver Kconfig in /drivers/pl/Kconfig to add the configuration information needed for my PL driver:
    menuconfig PL
    tbool "Programmable Logic Support"
    tdepends on HAS_IOMEM && OF
    thelp
    ttAvnet Programmable Logic Support
    if PL
    config PL_DEBUG
    tbool "Enable Debug Message"
    config LEDBRIGHTNESS
    ttristate "LED Brightness Controller"
    thelp
    ttThe Avnet LED Brightness Controller
    endif # PL
    Edit the /drivers/pl/Makefile to add the appropriate source files to your kernel build.
    obj-$(CONFIG_LEDBRIGHTNESS) += led-brightness.o
    Finally you will need to edit your kernel config file to add your new driver configuration to the list and specify whether it is to be built statically or built as a dynamic kernel module.
    Once you are done setting up the source tree, you should be able to build by using the following command:
    make ARCH=arm
    Using the updated configuration and Kconfigs, the kernel should end up building only your new driver (plus and added dependencies) into the kernel image or kernel module depending on how your driver was configured.
    -Kevin
    Hello Kevin,
    menuconfig PL
    help
    if PL
    config PL_DEBUG
    help
    endif # PL
    Is above step common for all drivers or its special for your driver?
    where do you find kernel config file? and what changes you made in it?
    after you get kernel image including static module, how do you test it on zynq board?
    Please Guide.
    Ganesh.
