Software Application Development MicroZed UART not receiving proper data
  • Subscribers 364 subscribers
  • Views 1057 views
e14 Contributor over 8 years ago
Hi folks,
I am moving from Zybo to MicroZed. I have a software application which was perfectly sending data though the Zybo's UART (JTAG UART), but now it is only receiving wrong data/characters after installing the CP210x uart-to-usb bridge drivers.
I have tried different baud rates whitout any luck. Moreover, the default configuration of the CP210x is the same as the Zybo's UART, so I have no clue what is going on.
Best regards,
Cerilet
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Cerilet,
    The MicroZeds default configuration for its UART terminal is 115200/8/n/1/n. Please try this and let me know if it solves your issue.
    --Josh
    0 e14 Contributor over 8 years ago
    Thanks for your answer Josh,
    Yes, that's the configuration I've used.
    When writing this command: printf("\n=== START ===\n");
    I get this: rlòll ì ’€Œ‚ llll`
    I have used the same base Vivado project changing the Zybo for the MicroZed, and I have not changed anything from the UART configuration, and the C software is exactly the same. Very weird.
  • jafoste4
    Does a simple Hello World application work properly with your MicroZed?
    --Josh
    0 e14 Contributor over 8 years ago in reply to jafoste4
    Yes, the program works nicely, but not the UART. I have tried as well in linux using minicom and it behaves the same way.
    Could be related with the endianness of the data?
  • jafoste4
    Hello Cerilet,
    When you generate a baremetal Hello World application from the Xilinx example application template does it run successfully and does it display over the UART in the terminal Application?
    --Josh
    Yes, that worked Josh.
    Apparently, Vivado does not reconfigure the Zynq block when changing the board on the design. I opened another project where I used the MicroZed to set the same timing values but that didn't work either. I tried as well to remove the Zynq block and add it again with no luck. I had to start a new project from scratch. What a waste of time...
    Thanks for your help anyway.
    Cerilet
