Software Application Development xutil.h not found
  • Subscribers 363 subscribers
  • Views 360 views
xutil.h not found
I'm following lab 6 of the hardware speedway (http://zedboard.org/course/developing-zynq%C2%AE-7000-all-programmable-soc-hardware-vivado-20133)
when following the steps up to page 5, somehow the xutil.h file seems to be missing in my project.
Should this file have been included when my BSP was generated? this seems like a very 'common' file, but the SDK tells me it cannot find it.
    It should be in the 'include' directory under the BRAM_DMA_Test_bsp/ps7_cortexa9_0/ folder. Make sure you have selected the correct bsp for your project. You might want to perform a 'clean' to make sure it gets included correctly.
    -Gary
    I've also seen this very same issue when trying to perform hardware lab 6. I'm presently using Vivado 2014.3.1. Perhaps something has changed since the document was created seeing how it was originally done with version 2013.
    In order to circumvent this issue, I simply found the xutil.h on my system and imported the file into my application project. Once imported, I was able to successfully build the project.
    I was wondering if anyone knew the exact reason to this problem? I'm pretty sure I followed the exact instructions as described in the lab.
